Corrosion in engine bay
Old Jan 22, 2008 | 03:15 PM
griego89's Avatar
W220 S430
Hey guys i'm a newbie here in the forums and i need some advice. I just bought a 04' S430 from Illinois and it has a good bit of light corrosion visible on the block (white splotches). Can I just pressure wash the motor with water to get this off or is there a special chemical i should use? Also there is light rust on the engines' pulleys, am I pretty much stuck with that?
Old Jan 22, 2008 | 03:19 PM
jfendis430's Avatar
S430 Sold :(
Was the car ever under water that you know of??
Old Jan 22, 2008 | 03:30 PM
griego89's Avatar
W220 S430
the car was never underwater.
Old Jan 22, 2008 | 04:02 PM
kenstudios's Avatar
If you pressure wash your engine bay, you stand a chance of getting electrical problem as the high pressure steam will get into your wires and cause shortages. Engine bay is was with engine cleaner/degreaser and very low pressure water.
