FS: Xenon headlight parts
2011 C 300 4-Matic
I have a whole stock xenon headlamp assembly with bulb, ignitor, control unit, etc. The only problem with it is the mount on the housing is broken. Let me know if you need anything.
2011 C 300 4-Matic
Im pretty sure it came out of a 2001. Ive had it in my garage for a little while and Im trying to clean out most of my parts. Make me an offer on anything you might need. I'll take any reasonable offer.
You'll probably be better off selling the bulbs and ignitor separately since you said the mount is broken, that means the bulb doesn't seat properly in the housing and will be shaking and vibrating then cracks. Sorry for my 2 cents.
2011 C 300 4-Matic
Yea I am selling it all separate. Thats why I said let me know if you need anything. Also its the headlamp assembly mounts that are broken not the healight bulb mounts. So the bulb wasnt able to shake around. The headlamp assembly was rigged up to hold it in place but it wouldnt pass state inspection so it had to be replaced.
how much for the whole assembly? I really only need the bulb holder, and well a bulb, my headlight has a damaged bulb due to a broken bulb holder.
Also is the headlight lens interchangeable on this? or is it like sealed in with sealant?
2011 C 300 4-Matic
Make me any reasonable offer and I'll probably take it. Its not doing me any good sitting in my basement. The new unit I replaced it with was over $2000 because everything is included. All the bulbs, wiring, control unit, housing, etc. I think you can take the lens off because it has clips that hold it on but its got some sealant too so I dont want to take it off and break the seal unless needed.
