Air Matic or ABC suspension
Hello all,
I have a 2000 S500 witht he AMG Sport Package.
How can you tell if you have the air matic suspension or the ABC suspension.
I have the button on the dash to raise and lower the car. I noticed that some W220s have different buttons. Some has 2 settings and others have 3 settings. My button only has 1 light on the button so I'm thinking that I have the 2 setting type.
Does that mean I have the ABC suspension?
Also, I noticed that the left rear of my car sits lower than the other 3 corners. When I push the button on the dash to raise it, I see that it does go up, but still not the same height as the other 3 corners.
Does anyone know what the problem could be? If so, how much will it cost to fix?
Thanks for all your help guys.
Hello all,
It sounds like you have a bad valve, strut or leaking strut seal. You should have it taken care of quickly because if it's a seal the excess operation will blow your Airmatic pump.
On the W220, ABC was available from 2001 in the US. It was standard on all US CLs, 600s and S55s/S65s as well as latest generation SLs. As far as I know it was an orderable option on all other 8-cylinder rear-wheel drive W220s. ABC is code 487.
