TPMS Reset? Is it possible?
Old Apr 4, 2008 | 08:39 AM
DRTYLNDY's Avatar
Hello. Does anyone know if I can reset my TPMS myself or do I have to have the dealer do this? It keeps displaying Tire Pressure Monitoring System Inactive. Any help would be great. Thanks in advance.
Old Apr 4, 2008 | 11:36 AM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
Yes it's a simple DYI. Scroll to the TPMS on the dash display, push the reset button to the right of the steering wheel. The TPMS will tell you that it will take some drive time in order to give you the new reading. In my experience around 10 to 20 minutes of drive time. If takes longer be patient, don't keep reseting.
Old Apr 4, 2008 | 09:59 PM
DRTYLNDY's Avatar
Well I tried that and it still states the same thing. Tire Pressure Monitor System Inactive.
Old Apr 4, 2008 | 10:07 PM
brakel8's Avatar
ML500 AMG pkg
Ussually when the system displays inactive there is a problem with either a sensor or TPMS module. If the system doesn't read a single sensor it turns the entire system off.
Old Apr 5, 2008 | 09:30 AM
DRTYLNDY's Avatar
That is what I thought. Thanks for the info.
Johan
Old Apr 5, 2008 | 12:28 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
I just went through this myself. The thread at https://mbworld.org/forums/showthrea...highlight=tpms has some interesting information, especially beginning with my06clk's post at #18.
You should check your cold tire pressures before reactivating the system. If the actual tire pressures are too far from one another, especially left-right, the system will not reactivate even after driving 20 to 30 minutes. Also, ensuring proper inflation at the time of reactivation properly calibrates the system. Upon reactivation, the TPMS will read front 29, rear 32, no matter what the pressures really are (as long as they're close enough for the reset to occur at all). To keep it accurate, your cold pressures should be 29 and 32 when you reactivate it. When I did that, my system was reactivated after less than 5 minutes of driving. I rechecked actual tire pressures after it reactivated, and the TPMS was accurate.
if the system will not reactivate despite those steps, then either a single sensor is bad, or the main unit is.
Old Apr 16, 2008 | 12:33 PM
kalel21's Avatar
2004 S500 AMG Kit Keyless go Parktronics 7 speed
Thanks for the info saved me alot of money and time!
