02 s600 sirius
02 s600 sirius
anyone add a factory D2B Sirius unit to this yet? it is an early 02 also. it also has the separate changer in the rear with the nav unit left side trunk..
All I could show on a picture would be the head in the center console top compartment. I dont have a phone connected so it worked out fine to put it in there..
I went to Best Buy and got a XM radio and the antenna adapter. You simply pull the antenna out of the radio, plug it into the adapter and plug the adapter into the MB radio and the XM radio. When I turn the XM radio on it hooks the XM radio to the input of the MB radio and I happen to use 88.1 mhz on the FM dial. The XM radio transmits the signal to the MB radio on 88.1 mhz FM.. It really works well. When I want to use my MB fm or am radio I simply shut the XM radio off and all works as it did before.
