w220 help
The car was PERFECT when I parked, with only minor issue history since purchase.
I went to the starter relay, removed the cover and manually closed the relay - the engine cranked freely, but of course something is NOT supplying the right information to start the car. I did leave the key on in the ignition for a few hours - nothing there.
Also, the Fuel Pump relay is under the seat. how do you get it out, the plastic around it restricts its removal. Does that entire fuse box move in some way to allow fuse access?
This has to be simple, but I dont see it. help...........
(also posted on benzworld)
W220 CPS
There is this page that tells how to test for W164. I'm not sure if it's the same for W220.
http://www.benzworld.org/forums/w164...-test-cps.html
Are you getting a check engine light or anything? Some threads I've seen for diff models say that CPS does not throw an error.
Does anyone know that the CPS can stop the car from cranking in total?
W220 CPS
