DIY? Replace Driver Side Mirror
Old Apr 20, 2008 | 02:37 PM
Gondon's Avatar
02 S500 Sport
Anyone can give me insight as I need to change a bad mirror.
It is easy or do i need to go to a shop for it.
Old Apr 21, 2008 | 01:25 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I don't think you need to go to the shop, but it depends on your skill.
THe housing is very easy to come off. Adjust your mirror so that it goes towards the car as much as possible. You will see a metal clip in the center of the housing. use a small driver or something to press the clip and pull on the housing to release. you will then have to adjust your mirror back to a straight position so that you can pull the housing straight off.
The mirror is held on by a plastic circular locking device that you will see when you remove the housing located at the rear center of the mirror. Just turn it I think counter clockwise and it will free the mirror. Watch the connector for the heater if you have one.
If you have to remove the entire assembly, there are three torx bolts that hole it on. you may have to fold the mirror to gain access to the last screw I cant remember.
Why are you on Probation?
Old Apr 21, 2008 | 12:21 PM
kenstudios's Avatar
And you need torx screwdriver number 20. Easy DIY.
Old Apr 21, 2008 | 12:33 PM
Gondon's Avatar
02 S500 Sport
thx guys , ill practice on my other driver side mirror case, I have the whole damn unit rofl.
Probation for some crap in off-topic.
