Vibration from A/C
Old Jun 18, 2008 | 10:24 PM
gac's Avatar
gac
2002 S500 black/java/2011 Escalade (wifes)
Vibration from A/C
it seems when ever I turn on my a/c my car starts to slightly vibrate. I've driven other cars and even if the a/c is at its max there is no vibration. Should I be concerned or is this normal?
Any help would be appreciated
thanks
Old Jun 18, 2008 | 10:42 PM
whoover's Avatar
'19 E63S sedan
You shouldn't feel the A/C compressor. You might have bad engine mounts, which are largely responsible for smoothing out vibration in these cars.
Old Jun 18, 2008 | 11:49 PM
gac's Avatar
gac
whoover, as usuall thanks for the quick response! If it is the engine mounts do they get replaced? Or do they get loose and get tightened? I know I probably sound dumb but...... And what should I expect to pay for any repairs?
Thanks for your help!
Old Jun 19, 2008 | 12:09 AM
whoover's Avatar
'19 E63S sedan
If it's the mounts, they have to be replaced. The mechanic can tell because they collapse (there's a simple measurement they make). The cost depends on whether all mounts need replacing. Often, the transmission mounts need replacing at the same time. It's usually not a gigantic bill, but nothing is cheap on a Mercedes. I would say hundreds, not thousands.
But it could also be a bad idler or even A/C compressor, although my bet would be on mounts. If it were bad moving parts, you'd probably hear noise when the A/C engages. In my experience, rough idle type problems are usually collapsed hydraulic mounts on these cars. But only a reputable mechanic can say for sure.
