HELP! Found 1 wheel sitting in the wheel well after 3 days of no driving
Old Jul 1, 2008 | 06:24 PM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
I just realized this is the second time this happened, I remember when I first left the car sitting for a few days (2 weeks ago) I got into it and noticed a big bump-up when I put it in drive, like I drove over something big.
This time, I saw the rear driver-side was sitting a bit low when I walked to the car, then saw the rear passenger-side was IN THE WHEEL WELL!! And the Passenger front was also low.
I started the car, same results, then put it in park, and again, the big BUMP feeling like I drove over one, and back to normal.
This is an ABC Car. What do you guys think this could be, and should I be worried that I'm sitting on a ticking time bomb? Also, expenses to fix?
Old Jul 1, 2008 | 06:43 PM
CynCarvin32's Avatar
Mercedes Benz
Sounds like leaking valve blocks front and rear. Could be shocks as well. Do you have leaking fluid under the car? If not the valve blocks that control the shocks are likely leaking pressure internally and allowing the car to sag.
Its not cheap as tehy run about 1200 a piece plus labor?
Shocks are about 1500+ plus labor.
Old Jul 1, 2008 | 06:55 PM
K-A's Avatar
K-A
I totally forgot to check for leaking Fluid, but I don't think there was....
How long do these things normally hold up before it becomes undriveable?
