ESP,BAS & AIRMATIC ERRORS AT THE SAME TIME
Old Jul 11, 2008 | 03:45 PM
J1013's Avatar
SL550
My 2000 S500 (50K Mileage)was running fine.I shut it off and when I returned to the car 5 minutes later and started it up I had 3 malfunctions coming up on the screen. They were ESP Program,BAS Brake Assist and Airmatic. How should I be trying to find out what the problem is? Appreciate all the help.
Old Jul 12, 2008 | 11:00 AM
kenstudios's Avatar
This happens when your battery power is disconnected or your car looses power for a short period. Try turning your steering all the way to the left then all the way to the right. It should clear the errors UNLESS you have a true problem with these functions then the errors will come back.
Old Jul 12, 2008 | 05:45 PM
02S430's Avatar
W220 M113K
can this also come from a weak battery? TIA
Old Jul 12, 2008 | 10:23 PM
biigii's Avatar
2000 Mecedes Benz S430
I had the exact same problem and it turned out to be the weak non-standard battery. I replaced it and problem gone now. check your battery.
Old Jul 20, 2008 | 12:47 PM
Laubscherc's Avatar
W202 C200 1998, W123 200 1982, W123 230E 1982
Same here, check the battery and connections.
