i need help finding new brake pad oem does anybody know??
mercedez benz s430 4matic
Hi my s430 4matic brakes stared squeaking and I need them change before something goes bad, I don’t want to take to the dealer they are ripoff I would just do it my self does any body have suggestion and were can i find the oem brake pad
2003 S500, 03 C240, 03 E320, 03 tahoe
talk to phil
mercedesshop.com,he has never made a mistake on any of my parts and the prices are really good.all replacement parts will support factory warrantys.
2005 S500 4-Matic, 1978 450SL
For one thing, your brakes may squeal for reasons other than wear; there is a paste that can be applied if wear is not the problem. If your pads are worn to the point of needing replacement (assuming they're original), your should get a warning light triggered by brake wear sensors in the pads.
If your pads are worn to the point of needing replacement, you also most likely need new rotors as well. You don't turn MB rotors.
And if your did get a pad wear warning, you'll also need new wear sensors for the new pads.
