Loose Shifter
Old Sep 5, 2008 | 05:37 PM
kelbo's Avatar
Loose Shifter
The shifter in my s430 is loose,lots of play. Is there a bushing that's worn?
Old Sep 5, 2008 | 06:41 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Take a look at the shifter connecting rod under the car. If there is play, it will be there. There are no bushings that you ca put in the shifter. You have to replace the entire module. But if your play is front to back, its not the shifter.
Old Sep 6, 2008 | 03:20 AM
rccmerc's Avatar
Here is a pdf to give you and idea how it is setup
File Type: pdf
