2004S COMAND and V60s
First, I'd check that they don't have grunge collected on them, and that none are bent or pushed in so as not to make contact. If things are OK there, I'd look at the connections inside the console (use the phone bulletin for your car at http://home.earthlink.net/~phdwebsit..._bulletins.htm)
Also, the OE cradle for the V60S phone is larger than for cradles for older models. Using the older cradle with a V60S can cause poor connections as well.
