anyone running a non-staggered setup?
W220
I am potentially considering a set of wheels that are 19x9.5 all around. Does anyone run a similar setup? Would you run the same size tire for all 4 or are you using a staggered setup? What is the ideal offset for a 9.5" wide wheel? ET35?
TIA
Steve
TIA
Steve
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
If you want to run non staggered 19's you will need 8.5 rims with 245 40 19 tires.
Ideal offset depends on the wheel but normally 35 to 38ish for 8.5 /19 and 35 to 40 ish for a 9.5/19
2005 S500 4Matic
Unfortunately, you don't mention what kind of W220 you have. For a 4Matic, for example, you shouldn't go for a staggered setup, unless you make sure that the rolling diameter (revolutions per mile) of the front and rear tires are the same, otherwise you will wreck your drivetrain.
Refer to this thread for details
https://mbworld.org/forums/s-class-w220/256035-vibrations-70mph.html
W220
i took a look at the wheels yesterday, and the seller was a housewife that that was selling the wheels for a friend that moved out of the country. she measured the wheels with a tape measure and subsequently posted the wrong size. when i got there i turned the wheels over and they were actually 18x8.5 et 35 from a clk. too small for what i'm looking for so i passed on them.
