w221 wheels on a w220??
04 S430 and 07 E350
Would these wheels fit an 04 s430?
It says they fit the w220 but I think these were a w221 factory wheel option. The first link is to the 19x8.5 and the 2nd link is to the 19x9.5
It doesn't show the offset in those links though. According to discount tire, the w220 and the w221 use the same offsets for the same width of wheel.
http://www.finishlinewheels.com/MERC...07/A-65468U85/
http://www.finishlinewheels.com/MERC...07/A-65469U85/
Here are those same wheels mounted on an 07 w221...
![](http://photos.ebizautos.com/5859/3395631_7.jpg)
Thanks,
Ben
Thanks,
Ben
The wheels will fit but you'll need different size of tires. You'll have different diameter of wheels/tires if you use W221 stock setup.
W221 19" can take 255/40/19 fronts and 275/40/19 rears
W220 19" can take 245/40/19 f, 275/35/19 r
You can buy the wheels but you'll need new tires. For 4-matic, you can use the front tires size for f/r.
