Is a cd changer/iPhone switcher possible?
http://www.speed-detectors.co.uk/cat...acturers_id=16
The Gateway 500 Version 3 hardware is similar to the one in the link provided by kenstudios, except that next to the "input" (1 in the diagram), there is also a second input. Input (1) becomes labeled "Car" and the second input is labeled "CDC."
Mounting the GW 500 in the trunk is a difficult proposition because its iPod, USB and RCA inputs need to be in the console, and the wires for those are not long enough to go from the trunk to the console. One avenue would be to lengthen them, and put the GW 500 electronics in the trunk where the CDC could connect directly to the "CDC connector" of the GW 500; and if you have an unused fiber optics lead (such as for voice control) that would connect to the "Car" connector of the GW 500 (connecting it in turn to the head unit), then I suppose it could be done.
Otherwise, you're into running that additional fiber optics lead from the trunk to the head unit area again.
In all, it is probably better just to decide whether to use the iPod/iPhone music or the CDC before starting to drive.
I don't know of any other fiber optic solutions that would let you change "on the fly."
