Tech help Trans Code p0730!!!
Old Mar 28, 2018 | 05:00 PM
FlyHigh985's Avatar
1997 e320
The only code i got was p0730 incorrect gear ratio was you filter fitting flimsy and hanging downz when you installed it?
Old Mar 29, 2018 | 08:48 AM
iamrclose's Avatar
2004 E320 & 2013 E350 4matic
P0730
That was the same code I got as well which the conductor plate is the first thing as well as the plug with the o-rings. The solenoids were right there so rather than going back in it again I went ahead and replaced them. The fitment was fine with the filter on mine. Good luck with everything and let me know if you have any other questions .
