Wheel question?
Old Nov 30, 2008 | 06:26 PM
jfendis430's Avatar
S430 Sold :(
Wheel question?
Does 19 AMG wheels from a cls55 fit on a w220?
the wheels in the picture are what they look like.
Attached Thumbnails Wheel question?-2005-mercedes-cls-55-amg-side-1280x960.jpg
Old Nov 30, 2008 | 07:52 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
THEY WILL. first you need to get shorter lugs like the ones that come with the CLS. if you use the factory CLS tires is a guaranteed rub !!!my cousin has the SL500 wheels on a S430 but using the 245/45/18 and 265/40/18 . i know their 18" but would make the same effect with 19" . i know this because I've done it . i had my SL500 18" with 285/35/18 and it would rub most of the time. same append with the 285/30/19 . you can use the wheels but i suggest you change tire size to the recommended S class size.
Old Nov 30, 2008 | 08:16 PM
jfendis430's Avatar
S430 Sold :(
Thanks for the info. I sold my car to my cousin and he found 19 AMG wheels in san diego for like $500 but no tires so I will let him know to run a bit smaller tire size for the wheels to work with no rubbing.
Old Nov 30, 2008 | 08:53 PM
m4xm1l10n's Avatar
For the S Class should be 245/40/19 F 275/35/19 R ALSO ASK THE DEALER FOR A SET OF CLS500 LUG NUT .
Old Nov 30, 2008 | 10:05 PM
jfendis430's Avatar
S430 Sold :(
thanks again also he might have a set of lugs that will work off some 20's that were high et's he was running before these new wheels they might work I will have him double check.
