passenger door controls
Old Dec 16, 2008 | 11:08 AM
lavard1@verizon's Avatar
2005 s500 4matic
i left my window open a bit in the rain, now none of the passenger side door controls work.
Old Dec 16, 2008 | 11:45 AM
whoover's Avatar
'19 E63S sedan
The DCM (door control module) is susceptible to water damage. You will need to have it replaced.
Old Dec 16, 2008 | 12:11 PM
2005 s500 4matic
do you have a idea on the cost of the dcm?
Old Dec 16, 2008 | 12:13 PM
2005 s500 4matic
do you know how much a dcm costs
Old Dec 16, 2008 | 12:19 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
about 900 with parts and labor...look on ebay you might be able to find it cheaper??
Old Dec 16, 2008 | 01:08 PM
whoover's Avatar
'19 E63S sedan
Are you off warranty? They would probably fix it since leaving a window open is not normally considered abuse. You could also claim that the window seal should protect the inside of the door.
Old Dec 16, 2008 | 01:26 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
The DCM is not that expensive check with your parts and then try a few dealers around they usually differ in prices for some reason. It's around 400ish for the part maybe less. very easy to change.
First I'd do what whoover said.
Old Dec 16, 2008 | 04:38 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
true they cost around $300 + and easy to install !!!!! door panel out part in , just like an average car i did it once to my 02 S430
