Airmatic Issues
Old 01-12-2010, 06:44 AM
mark7's Avatar
Mercedes CLS
hi
Old 01-22-2010, 09:01 AM
karim jamal's Avatar
s280
Has anybody had a problem with the control unit located next to the airmatic relay.
Old 01-22-2010, 10:08 PM
socalsounds's Avatar
2012 CLS63 AMG Performace - Obsidian Black
Brenner said...
Does your car make air hissing noises when jacking it up? Or after you shut it odff? If yes, you have a leak.
My car, and my friend's as well, adjusts it's height after shutdown, and sometimes when opening the door or locking. My indy advised me that this, along with the hissing sound as the air self-bleeds, is normal.
So, not all hissing sounds indicate a leak! BTW, new front struts (under warranty by the last owner on the VMI) as well as new pump.
Does everyone elses lower a bit and adjust after shutdown or door opening?
Chris
Old 01-23-2010, 10:24 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Yes, it is normal, and it has been discussed a number of times in the myriad airmatic posts. After shutdown, the ride height sensors are still active for a time. When yiu exit the car, it rises just a but. The ride height sensors register the rise, and direct a short bleed of air to lower the car to the prescribed height.
Quick Reply: Airmatic Issues
