Brake light problem
Old Jan 1, 2009 | 07:55 PM
WhiteBlkBenz's Avatar
S-ML-E36
Brake light problem
My 00' S430 has a problem with the brake pad sensor. The brake pad light is on and I have to reset it every time I start the car, I know you understand how annoying is that. The sensors are good. I kinda tracked down the problem to the fuse box located on the engine compartment (drivers side).
Does anybody knows about this problem? I bet is a loose connection somewhere but I wanted to ask the gurus here before I troubleshoot it all the way.
Old Jan 2, 2009 | 07:01 PM
blas0827's Avatar
none
no it one of the sensor wiring check the wires to see if its grounding out
Old Jan 2, 2009 | 07:34 PM
S-ML-E36
I'll look for that. Thanks
