aftermarket amp/sub problem
Old Jan 4, 2009 | 03:49 AM
bigbodybenz02's Avatar
2002 S430
Whats up guys,
I have an aftermarket system in my 02 s430 but its been giving me a problem. Ill be listening to the music but all of the sudden it will get really loud and then go really low non stop. It mostly occurs when i start to adjust the volume. I have used all different kinds of hi-lo converters and rewired the system completely but still same problem. Has anyone ever heard of this, and if so what can I do to fix it?? Thanks for the Help
Old Jan 4, 2009 | 03:28 PM
Oxygen's Avatar
W220 S65 AMG
I think that your internal microphone that is used to auto-adjust the volume might be causing a problem.
If you pull apart the OCP there should be a microphone inside - clip one of the wires going to it.
This is only true if you are using OEM COMAND.
Old Jan 4, 2009 | 08:15 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
If its aftermarket,
How can it be the OEM? more info would help/ IE:
WHat system,
How was it installed?
How is the volume controlled?
If its 100% aftermarket asking a question here is useless unless someone has thae same system installed which you did not identify.
