s430 trunk-lid question
Open the trunk and remove the liner. There will be two nuts or bolts directly behind the insert inside the trunk lid that need to be removed. After that, the insert can be taken off but be careful it still has clips that require you to pull away from to get it free. I would remove the license plate first also, as either the top or the bottom set of screws go all the way through.
Good luck...
Big "H"
