Airmatic problem pleas help
Old Jan 16, 2009 | 09:32 PM
samvel1981's Avatar
W124 E320, w210 E420,W210 E55 AMG,W220 S430 (sold),W163 ML 55AMG
Lightbulb Airmatic problem pleas help
hello evry one i have 2000 S430 and it is have Fu**in Airmatic problem pleas help ....... ok hear whot i got , the fuse's and Relay's everything is OK , the pump is ok i did hard wire so it is good , but when car started i don have any power going to the pomp at all .
and the valve that is bolted an top of the pump the one that all the houses going to it wont let the air go true when i hard wire the pump ... any idea whot is the problem ? pleas let me know
sory for my english thenks
Old Jan 17, 2009 | 04:32 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
If you have no power going TO the pump, then your fuse or relay cannot both be good.
It is possible for your pump to turn, but not put out adequate pressure.
It is also possible that everything up to the pump is good, but that the valve block on top of the pump is bad.
Have a qualified MB technician diagnose it.
Old Jan 17, 2009 | 11:43 PM
samvel1981's Avatar
the raleys are good very good i change them many times i have like 10 of them they can be all bad or is ther spasific relays need to be use like spacial voltege or amps ? but i think they are all the same iven if they frome diferent cars or im wrong ?
Ok my pump is working when i conecting inside the relay manualy . The sensors working to wen the car is lowerd it is showing that stop - car is to low but wen i raise the all car up in the air and start the car it is showing airmatic visit vork shop only.
the only problem im tink of is the airmatic magual or the valve block so how can i chek that ?
and wer is the airmatic magual locaid unther the hood or inside the car ???
Old Jan 18, 2009 | 09:17 PM
Skylaw's Avatar
I have no idea whether relays from other cars will work. The relays that have the proper pins and voltages are at post #10 at https://mbworld.org/forums/s-class-w...ic-issues.html
You need to have the car checked by a certified Mercedes technician. It is pretty clear that you do not understand enough about the system to troubleshoot it by yourself - and you definitely have a malfunction, and it may be serious. A certified technician can diagnose the exact problem and properly make repairs without causing additional damage, and also without replacing parts that do not need to be replaced.
I am sorry, but I do not know what you mean by "magual."
