Loud clicking under the drivers wheel wall
Old 02-19-2009, 10:46 PM
ebolick's Avatar
2000 S430, 1999 E 320, 2 K5 blazers,
Okay i have three post as i have three different problems
Now my battery is dead, no lights car wont even unlock the doors, now i have this loud clicking under the drivers side wheel well that wont stop. i dont understand if the battery is dead what can be powering this sound?
Any ideas?
Old 02-19-2009, 11:44 PM
ebolick's Avatar
Okay so now i unhooked the battery and the noise is still there? anyone had this problem when the battery is unhooked?
Old 02-20-2009, 12:28 AM
whoover's Avatar
'19 E63S sedan
It's probably your alarm siren, which is supposed to go off when your battery output drops, in case someone is trying to jack the car. It has its own battery, which is probably almost dead. That would be coincidental to your main battery being dead, which was predictable based on your cluster not sleeping. What did you think would happen?
When you get your cluster or other electrical problem fixed, you might want to consider having them look at the siren.
Old 02-20-2009, 12:43 AM
ebolick's Avatar
thanks that makes sense.
The problem started when my dash lights would not turn off. then i got a really quick message on the dash cluster that goes away after 5 seconds "display defictive" the gauges work fine however the dash light will not shut off i tried everything. well the battery ended up draining as it stayed on over night.
when i got home today there was a loud clicking but the battery was dead so i jumped it the car and the noise went away, but when i unhooked the battery it came back but not as loud.
Old 04-04-2009, 02:25 PM
Quadcammer's Avatar
96 and 08 911 turbos
Did you ever figure out what the cause of this was?
My mothers E430 does the same thing...
Old 04-04-2009, 05:48 PM
ebolick's Avatar
yeah it was the car alarm horn, when the battery is very low or dead it makes this noise, it will go away once the battery is charged or replaced.
Quick Reply: Loud clicking under the drivers wheel wall
