Funny noises---@#$%
Old Mar 26, 2009 | 10:40 AM
E43 S's Avatar
'00 S-500, E-430S, '88 Mustang
Funny noises---@#$%
Has anyone experienced a "Creaking sound" or a "Rusty hinge" sound coming from the front suspension and steering rack??
Last weekend I had my car on a lift 4 times in one day....and well 2 days later, I started to hear a creaking sound when I turned the wheels left, and right, as if it was rusted for years and Im driving it for the first time. Then next day, when I drove over man holes on the street i noticed that I have a similar sound coming from the suspension.
What gives?#$%#
It sounds as if I had a Horse-n-Carriage suspension....embarrassing...never had this problem before.
Old Mar 26, 2009 | 12:20 PM
DAMIT's Avatar
2000 S Class & 2004 SLK
Also have this problem! Only happens after a long trip or hour or so use. Just get the creaking noise from the steering, no other effect.
Just assumed the steering rack or power steering unit getting hot & bothered and maybe worn. Disappears next morning.
Old Mar 26, 2009 | 01:02 PM
ssonss1's Avatar
Flying Spur
i had the same problem...replaced the lower control arm...search the thread
Old Mar 26, 2009 | 01:40 PM
E43 S's Avatar
Damm.....what that cost u???
how long did u have that problem before u replaces them??
Old Mar 26, 2009 | 01:42 PM
E43 S's Avatar
U right........it almost nothing in the morning....and then 1 1/2 later when i get to work......its gets worse.... wonder if some WD40, or some grese would do the job...........
Old Mar 26, 2009 | 05:02 PM
LAWYER2's Avatar
15' W222
your ball joint boots need grease. I haven't inspected them to see if it's your standard grease fitting nipple, but if so you can do it yourself or a jiffy lube type place can lube them up.
Old Mar 26, 2009 | 07:08 PM
Benz5656's Avatar
SL500
Lower control arm, aftermarket $200, OEM $300 can be replaced in about an hour.
Old Mar 26, 2009 | 08:12 PM
E43 S's Avatar
thanx guys .....will do this weekend the grese part.....we ll see if that helps
Old Mar 30, 2009 | 12:21 PM
E43 S's Avatar
you were right-----
but instead I sprayed WD40, and added grease to the rubber under the strut mount and it did the trick,
Thanx!
Old Mar 30, 2009 | 12:59 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Originally Posted by E43 S
you were right-----
Thanx!
It'll be back. these part come sealed and do not require grease. If the grease is gone, the chances are the part is worn, adn will ned to be replaced sooner or later.. But glad you got rid of the noise..
Old Mar 31, 2009 | 03:30 PM
E43 S's Avatar
Thx for the info....at least its something that can be addressed at a later date.
