How hard is it to replace CV boots
Old May 22, 2009 | 07:41 AM
Adrianx's Avatar
2004 S500 4Matic
I have 2003 S430 4Matic and my CV boots are leaking. How hard is it to replace?
Old May 22, 2009 | 08:59 AM
Quadcammer's Avatar
96 and 08 911 turbos
Depends.
If you intend to use OEM mercedes parts, you'll have to remove the half shaft from whichever side its leaking from and replace the boot.
Some aftermarket solutions have split boots where you just wrap the boot around the cv joint, use seam sealer to glue the two sides together and then clamp it down.
Its not necessarily HARD per se, but its time consuming and can be a pain.
Old May 22, 2009 | 11:43 AM
Adrianx's Avatar
2004 S500 4Matic
Thanks!
Originally Posted by Oliverk
Depends.
It is just that I could not find anywhere for the split boot kit. My warranty will not cover the CV boot.... Funny.
