Question?!!!
Old May 29, 2009 | 04:32 PM
gamaraia's Avatar
S430
Question?!!!
Hey all,
couple of weeks earlier, i posted about airmatic and squeaking problem.
I sent my car to the shop, and it has been there for 3 days now.
The problem now is when i turn the car on it is suppose to automatically rise, but my car doesn't. The mechanic has been checking everything and he came up with the following:
it might be the air pump = it wasnt
it might be the hose = it wasn
now he said it might be the right valve = ???
any ideas?
Thanks in advance!
Old May 29, 2009 | 04:43 PM
JonMBZ's Avatar
06 C55, 09 E350
Probably a shock im guessing you didn't take it to the dealer....
Old May 29, 2009 | 07:26 PM
gamaraia's Avatar
S430
the shocks were both changed two weeks earlier...and from the dealer..
but there is something wrong...it doesnt rise :s
and it lowers by itself all the way
Old May 30, 2009 | 02:30 AM
gomdomin's Avatar
mercedez benz s430 4matic
take it back to the dealer... how much did you pay for the schock i need to change mine?
Old May 30, 2009 | 04:09 PM
4matic's Avatar
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
Post
weirdest thing...i had the exact same squeaking thing, like it was a shock...but i knew that wasn't it. i could tel lthe noise was comming from the front, drivers side. i hcnged my oil, and used the jack on the front drivers side...been a month and no squeak...probably just a fluke, but i found it EXTREMELY weird....good luck let us know what it is though
4matic
Old May 30, 2009 | 04:37 PM
illmeth0d's Avatar
2000 S430
Is the pump operating? If its on the car should raise. May be simple I had a relay that would work some of the time so change the relay and give it a minute to recognize. Hit the raise button at least 2x and cancel raise , raise again.
