Rotora Big Brake kit on CLEARANCE!
Former Vendor of MBWorld
Hey guys,
There's a set of ROTORA BBK available under clearance for your S-Class W220 (exc 4matic)
Features:
-Rotora billet aluminum alloy 6piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with �floating� disc assembly to reduce heat related stress and unsprung weight.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (355x32mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
8piston:
6piston:
Clearance Kits available in:
Front- 8 piston 15" / 6 piston 14"
Rear- 4 piston 15" / 4 piston 14"
RED & METALLIC BLUE Calipers with DRILLED/SLOTTED Rotors
**Will not fit 4matic
PM/EMAIL/CALL ME for pricing!
Features:
8piston:
6piston:
Awesome deal BJ. I PM'd you.
Chris, I'm STILL trying to get a hold of you. Should I call you at the shop? PLEASE get back to me ASAP via phone, PM or email. I need to hook up w/you and the shop on some mods I'm contemplating. Thank you.
Peter Humblias
Peter Humblias
