smartkey not locking or unlocking.
Old Aug 25, 2009 | 01:44 AM
Hercules86's Avatar
Sclass
after disconnecting battery to clean the maf and change filters my smartkey no longer locks or unlocks my car.
i bought new batteries for $20 at stealership thning that was the prob but it didnt soldve the problem.
DO i have to reconfigure key somehow?
any help would be great cause it real annoying using the valet key to lock and unlock
Old Aug 25, 2009 | 03:27 AM
kathmandurocks's Avatar
2001 S500
Same thing happened to my car too... took the car to the dealership... they couldnt figure it out cause it started working by itself..
Old Aug 25, 2009 | 03:38 AM
2001 S500
..........and ya, where did u get the car battery from. if the indicator light on the smart key flashes when u press the bottons the nothing is wrong wit the key. it could be the car battery. even the little difference in battery voltage can cause different problems. so please check u'r battery.... but if u gat the battery from the stealership then take it back to them, be little mad, ask for the manager, yell at him, u'r rest of the problem will be on the house....
Old Aug 25, 2009 | 09:10 AM
Quadcammer's Avatar
96 and 08 911 turbos
have you put the key back in the ignition yet?
Once you do that, it should work fine.
Old Aug 25, 2009 | 01:01 PM
Hercules86's Avatar
Sclass
I just reset the battery and keys now works
Old Aug 11, 2011 | 09:24 PM
beachbumbeeme's Avatar
2002c240
Smart key- Ignition no problem but doors and trunk will not open all the time. HELP!
This is a brand new smart key.
Old Oct 27, 2011 | 01:33 AM
mobiletechgeeks's Avatar
Land Rover, Mercedes, Ferrari
http://www.benzworld.org/forums/w203...pe-plus-3.html
