need help !!!!!! weird problem
Old Oct 12, 2009 | 09:16 PM
jasmin27's Avatar
s500
i have a 2000 s500 and whenever i push the pedal all the way down to the floor and push the little thing under the pedal the car doesnt move. even if i push the pedal down it wont move, the rpms dont even shoot up or anything. does anyone have any idea wats going on?
Old Oct 12, 2009 | 09:39 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Welcome to the forum.
If I understand your statement of the problem, https://mbworld.org/forums/s-class-w...n-problem.html and http://www.benzworld.org/forums/w220...ge-my-gas.html may help.
I really don't know what you mean by the "little thing under the pedal."
Old Oct 12, 2009 | 10:42 PM
S-Clusiv's Avatar
Whatever there's gas in...
I think the OP is referring to the kick down switch....?
Old Oct 13, 2009 | 06:32 AM
jasmin27's Avatar
s500
yea srry for the lack of better wording but the kick down switch as he said, thanks for the help, im gonna try the accelerator pedel module
Old Oct 13, 2009 | 09:58 AM
Ifari's Avatar
2000 CL500 1992 300SE
Accelerator pedal sensor or pedal value sensor and is found on the side of the gas pedal lever.
If that doesn't work try the electronic accelerator actuator, it is found with the MAF sensor removed. If that isn't it, try changing the EGR valve.
Good luck.
Old Nov 1, 2009 | 02:35 AM
99210's Avatar
1999 e320
replace accel pedal
