CD Changer Problem
Old Oct 19, 2009 | 04:03 PM
kcscout's Avatar
97' S320 & 00" S500
CD Changer Problem
Hey guys. I am a new owner of a 2000 S500. Among the problems I have is that my CD changer skips excessively on bumpy roads. I cannot imagine that is normal since antiskip technology has been around for years. I also own an older W140 (S320) and the CD's never skipped. what can be the problem. Will I need a new changer or just some adjustments, cleaning, etc.
HELP PLEASE.
Old Oct 19, 2009 | 06:06 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
All car CD changers skip a bit, the system stores a few seconds of the music in a buffer for when continuity breaks. Your problem might be caused by the buffer not working, no fix for it, just replacement.
Old Oct 19, 2009 | 07:10 PM
cameraman123's Avatar
2000 Mercedes Benz S500 Designo
Does it skip skip, or is it fading out into static?
Old Oct 20, 2009 | 12:40 PM
kcscout's Avatar
97' S320 & 00" S500
Some of both. This is my wife's car and she has been complaining about the cd changer ever since we got it. Her old car was a 98 S420 and the OEM changer was rock solid even on the most bumpy roads. I rode with her last night in the S500 and the changer could not complete a single song without excessive skipping and fading in and out. This is more that just a buffer issue. I figure I will need to replace the changer. I tried to remove the changer to confirm the MB part number on the bottom, but after removing the two screws holding the bracket to the trunk surface I could not lift the changer out. Is there another release somewhere. I could not see anything holding it down, but it would not slide up. Do I need to remove the amplifier at the same time as the changer?? That would be difficult as the lower mounting screws don't look accessible. Does anyone have removal instructions for this vintage vehicle??
Old Oct 20, 2009 | 01:07 PM
Reckless's Avatar
German vehicles stink, will never buy again. Moved on to Toyota and BYD.
I have the same problem, skipping and never re-buffering. I completely gave up on using it and use the in dash cd player.
Old Oct 20, 2009 | 01:30 PM
kcscout's Avatar
97' S320 & 00" S500
You can do that. I thought that CD slot was just for the NAV disks. It will play music CD's too?????
Old Oct 21, 2009 | 10:37 PM
kcscout's Avatar
97' S320 & 00" S500
OK, so I have been looking for a replacement CD changer and found several models but I am not sure which ones are compatible with my 2000 S500. Mine is a MC3010 but can anyone tell me if other models will work as well.
Old Oct 22, 2009 | 09:12 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
kcscout,
Your problem could also be caused by a dirty laser head (try a commercial laser cleaning disc) or a mis-positioned orientation switch. Most CDCs have a switch, usually on the bottom, that set its compensation for vertical or horizontal use. I don't know where the switch is on your unit, but the settings are marked H and V. It should be set to V.
You can get the part numbers for your CDC from the phone bulletin (yes, the phone bulletin) at http://home.earthlink.net/~phdwebsit..._bulletins.htm. Of course, it is also located on a label on the unit. You will need a replacement unit that matches that part number - the units are not freely substitutable, and I know of no 3rd party units that will work with COMAND. However, a web search will put you in contact with companies that repair the units, or offer overhauled units. Of course, the dealer will sell you a new one - it's expensive.
In your car the single slot in the COMAND unit is only for nav discs. Later cars and different models with COMAND had a single music CD slot in addition to the nav disc slot, but those were behind the nav screen. Your car does not have that. Don't put a music CD in the nav slot - you could damage the nav reader (but usually you'll just get a "disc not recognized" message or something similar).
Old Oct 27, 2009 | 02:12 PM
kcscout's Avatar
97' S320 & 00" S500
Skylaw: I confirmed most everything you said. I pulled my unit out to confirm which model I have and it is a MC3198 (not MC3010 as I thought). I had to remove the trunk liner from the entire driver side of the trunk to be able to get to the two strange nuts holding the amp portion of the bracket and to be able to lift the entire assembly out to see the bottom of the DC changer. I did not see any switches on the unit (for orientation). I did pick up a laser head cleaner and put it through the cycle multiple times. CD's will play fine as long as the vehicle is not in motion, in which case the CD's will skip repeatedly. I found a place in Houston that advertises a repair/return for this unit on eBay for $139. That will be my next move.
Thanks again for the assistance.
Old Oct 27, 2009 | 04:54 PM
Skylaw's Avatar
The "switch" may be a round recessed disc with a coin-width slot; if so, it will have a small arrow that will move from "H" to "V".
Old Oct 28, 2009 | 10:20 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
MP40 Player vs CDC
If your player is still giving you headaches check this out, a relatively simple, cheap and DIY solution
http://www.mercedes-player.com/epage...jectID=1489801
Old Nov 3, 2009 | 11:44 AM
kcscout's Avatar
97' S320 & 00" S500
How does the Command Unit interface with this MP3 player. How would you select from the tracks stored on the various disck you could insert?????
