2000 S430 transmission shift solenoid B problem
2000 S430
i have an S430 - 2000 model - the transmission does not shift from 1st gear trouble code indicates changing the shift solenoid B - I have - but the transmission still does not shift and the same trouble code is still showing up. anyone experience the same problem? HELP - please...
honestly, unless the car has a ton of miles on it which may think it would need a rebuild, I would get a new valve body for it.. You could try doing a flush or service to the transmission, but more than likely this isnt going to help you out.
