2001 s500
Old Dec 16, 2009 | 09:10 PM
prince2618's Avatar
2001 S500, Honda goldwing, 08 Expedition
2001 s500
I never had a problem with the car, drove to naples fl. returned parked the car the next morning it would not start. purchased a new battery the car started, but i did not drive the car. The next morning the new battery was dead. what's the problem. I charged the new battery but after you start the car the car dies-out. any answers to my problem now the ESP/BAS to shop light comes on. HELP
Old Dec 16, 2009 | 10:36 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
been a while since i have seen an amp draw on one of these cars.. Could be a couple different things, but the most common was the Command headunit (radio) causing the draw and killing the battery pretty quick like you are describing. Best thing to do is find some place local and have the draw issue checked out or do it yourself if you know how.. May take some time if you are checking it yourself, but if you have the right tools anything is possible..
Old Dec 17, 2009 | 04:55 PM
Fraser's Avatar
A Mercedes obviously!
My father had the same problem you describe on his '00 W220 and later found out that was the problem.
Old Dec 17, 2009 | 05:32 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Racin fool is right - battery drain can come from a number of malfunctions - CAN Bus malfunctions, a bad SAM unit, a door control module (See https://mbworld.org/forums/s-class-w...g-one-out.html) and even an IR sensor (see https://mbworld.org/forums/audio-ele...ml#post3779327). http://www.benzworld.org/forums/gene...ery-drain.html lists even more.
You installed a new battery, so this one likely does not apply, but I include it for others - http://www.benzworld.org/forums/w220...ery-drain.html
One way to test it is to hook an ammeter up to the battery, with the ignition off; the drain should show. Then pull fuses until the drain decreases significantly. There will always be some drain, but it should be small. You'd be looking for a large decrease in the drain.
Old Dec 17, 2009 | 09:36 PM
prince2618's Avatar
thanks for the information will get to work.
Old Dec 19, 2009 | 07:30 PM
prince2618's Avatar
thank you for the info it was the alternator, i saved hundreds doing it myself.
