Update On PAC Video Interfacing Or TVandNAV2Go
Old Jan 21, 2010 | 12:43 AM
Harley03joe's Avatar
2005 S 500
Post Update On PAC Video Interfacing Or TVandNAV2Go
Update Info For You Guyes And Gals.
I'm Not Telling You Guys This To Bad Mouth Anyone, But I Bought The "PAC"
Pacific Accessory Corporation UNIT VCI-MBZ 1 For My 05 Benz S 500
I Tried To Install It ,To Only Find Out That The Install Instructions That You Get With The Unit Or The Instructions On Line , DO NOT Match The Unit You Get, And Are Not Very Clear.
It's Altogether Different Nothing Is Very Straight Forward Lot Of Guess Work, Even When I Called The Tech Line I Did Not Get Much Help, So I Uninstalled It And Sent It Back For A Refund, So That's That For PAC VCI-MBZ 1 Unit, It Did Not Work, After I Had It Installed.
What I Then Did Was Ship My Dash Unit To TVandNAV2Go 7718 Flatlands Ave Brooklyn, NY US 11236 Talked With KIM She Said The Turn Around Is 24Hours And They Install The Unit Parts And Bench Test It Before It Is Sent Back To Me ,, All For $400.00 Then I'LL Have A Back Up Camera When I Put It In Reverse And Add A DVD If i Want.
Harley03joe :Smoker:
Here Is A Pictures Of Where I Put The Backup Camera On My 05 S 500
Old Jan 21, 2010 | 10:05 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Dang.. I'm disappointd. Thanks for the update joe...Let me know how the Tv Nav 2go mod works...$400 is not so bad.
Old Jan 21, 2010 | 02:16 PM
2005 S 500
Post
I Know I Was Disappointed Also, I'LL Let You Know Ok
TV Nav 2 Go Has My Unit Fri And I Should Get It Back Wed Then Put It Back In, I Already Ran The Camera Cable , Im Going To Get The Neg & Pos Off The Lighter Right There By The Unit Then Im Done
Yes $400.00 Is Well Worth It, They Do The Install And Bench Test It Before They Send It Back To Me.
The Other Unit From PAC Was Ok But No Instructions For Help And Follow To Make A Nice Install ,, There Instructions Are Old Ones With No Update And Are Not Very Clear To Follow, I Think That If A Co. Sells A Unit To Install At Least They Can Give Good Up to date Instructions.
I Think That Is B/S And For The Tech Folks Well Forget It There Is No Help There, So Your In The Dark, The Install Will Go As By Guess And By Golly, Not For Me So I Sent It Back For A Full Refund
Was My Back Up Lens Ok There ,, I Think It Will Work Out Great And Look Like It Belongs There
I'LL Let You Know
Harley03joe
