Removing Tail Lights/ Headlight Error!
and also i get an error saying "Check Left headlight" it keeps flashing on and off at times how do i fix this?
You will find that the search tool is your friend. However, to narrow your search a bit see the "W220 Owners Start Here" sticky on the first page of the W220 forum. Under "Body" there is an item dealing with headlight, taillight, side marker upgrades, etc - the link will take you to other links dealing with all of those topics. Those dealing with upgrading taillights tell you how to remove them.
The warning light for your headlight indicates a failing bulb or failing ballast resistor. You'll continue to have it until you address the problem.
