Pump Crapped Out
Old Apr 15, 2010 | 05:33 PM
Gondon's Avatar
02 S500 Sport
Thumbs down Pump Crapped Out
So last night as I was driving around the block looking for parking I noticed some burning crappy smell, I ignored it and thought it was the car behind me.
I park my car 2 minutes later on the next block and as I shut my car off and begin to walk, I hear a loud grinding noise as if a tire pump is running DRRR-DRR-DRRR. I approach my car and I realize its my car. I didn't understand what was going on as my car is off what the hell could that be, there was also that burning Oder. The first thing that came to my head was thats its the pump goints nuts. I restarted my car and put some weight on the front end and it would make that noise DDDRR-DRRDR-DDRR, then I moved it a little forward and back and it was gone, stood around for 3-4 min and no noise. I knew next morning the car was going to be on the ground and just went home.
I come this morning to check it out and it seems still fine. I start it up and it begins to drop like a brick slowly, 2 minutes later its almost on the ground. I push the raise button nothing happens. I tried to move it up and down nothing. 5 min later AirMatic Low stop driving...
I called up 02S430 for some advice and he came by and tried to help me(thx Chris). We tried the relay and battery but nothing. I guess now its time for a new pump and a tow
I found a pump for $300 on AutoHaus is this the correct one?
http://www.autohausaz.com/search/pro...pension%20Pump
Old Apr 15, 2010 | 11:34 PM
Quadcammer's Avatar
96 and 08 911 turbos
seems like the correct pump.
But get one in an MB box at parts.com for $220
2113200304 is the part number
Old Apr 16, 2010 | 12:14 AM
Gondon's Avatar
02 S500 Sport
Thanks, Oliver!
I found it
Part Number: 2113200304
Rear suspension - Ride control - Compressor Compressor, e320, e500, e55 2006
$220.80
Also I found the HELLA Relay for $24 there as well.
But when I type the part number for the Hella Relay(0025427219) in AutoHausAZ it gives me this one:
http://www.autohausaz.com/search/pro...ber=0025427219
I wonder if its the same.
Right now I'm more concerned what made the pump crap out with no warnings and just out of the blue. Age? a faulty relay causing it to go haywire?
I think my first step will be able to pop in a new relay, maybe the pump isn't fully dead and has some power left...maybe the relay shorted somehow.
Old Apr 16, 2010 | 12:42 AM
tusabes's Avatar
Mercedes
perfect stance, no need to lower using washers
Old Apr 16, 2010 | 08:16 PM
Il Capo's Avatar
ah man, sorry to hear that. It doesnt sound like it will set you back much, I guess the worst nightmare on the suspension is when the struts fail.
Old Apr 16, 2010 | 11:14 PM
chibenz's Avatar
02 S500
Originally Posted by Gondon
Thanks, Oliver!
I found it
$220.80
Thats the Relay Part NO. from autohausaz 0025421319
Old Apr 16, 2010 | 11:20 PM
B on my Benz's Avatar
E.FIDDY.FIVE AMG
it looks good tho
Old Apr 30, 2010 | 04:01 PM
Gondon's Avatar
02 S500 Sport
I need help. The nut holding the second screw is rusted beyond belief I tried Wrench, Power drill, pliers the head is now dead and I'm stuck what to do.
I removed the first one easily, this is the 2nd one and the 3rd one is at an almost impossible angle.
I hit a wall and put the wheel back on and left. I sprayed WD-40 and waited 10 min still no go. At this point I have no idea how I'm going to get it off.
Uploaded with ImageShack.us
Old Apr 30, 2010 | 07:03 PM
Quadcammer's Avatar
eh, have you tried heating it with a torch? that might help.
If really nothing works, just cut it with a sawzall and get a new bolt.
Old Apr 30, 2010 | 07:52 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Well to start will the first ?? if the pump was running after you shut your car off and walked away.. thats what burned the pump out your relay stuck.. You problably never noticed when driving it was on way more than it should of been..
The pump actually dosent need to run that much when your driving... and if there stuck on it dosent take that long to burn on out.. Make sure what ever relay you get make sure its the updated relay that benz approves ( they switch companies)
With the stuck nut, if you cut it off you might be able to save the braket but you'll have to tap the treads... But the stud might break off most dealers stock that braket they brake often.
Old Apr 30, 2010 | 07:56 PM
Gondon's Avatar
02 S500 Sport
I don't have a torch, but I do have some Jap lighter where the flame is about 1.5 inches high. I looked into a nut cracker, if I cant get it I will drill through the nut and make it snap in half.
Also there is some product called PB Blaster which is supposed to eat up rust.
Old Apr 30, 2010 | 07:59 PM
hcetzneb's Avatar
If the threads look bad just make sure you tap them before you put new nuts on....
Old Apr 30, 2010 | 08:29 PM
Gondon's Avatar
02 S500 Sport
I'll try everything. Gonna try vice grip pliers tomm maybe WD-40 is gonna do the job overnight. Also gonna buy PB-Blaster
Old Apr 30, 2010 | 09:01 PM
tusabes's Avatar
Mercedes
they have a freeze-off thing to crack nuts too
Old Apr 30, 2010 | 09:59 PM
Quadcammer's Avatar
pb blaster is good, but it can only do so much.
btw, you may want to look at your control arm bushings. Looks like there is/was some rubbing on the subframe.
Old Apr 30, 2010 | 10:51 PM
Gondon's Avatar
02 S500 Sport
Duestche Parts from Ebay for you. Spread the word to avoid that junk.
Old Apr 30, 2010 | 11:42 PM
tusabes's Avatar
Mercedes
i know this wont help you, but for others...
when you heard the compressor running after the car was off, couldnt you have just disconnected the battery or pulled the relay to prevent it from burining out?
Old May 1, 2010 | 12:08 AM
Gondon's Avatar
02 S500 Sport
Yeap, you need to pull the relay to save it. I just wish I knew about this back then, hopefully someone will save a pump by learning from this issue.
Old May 1, 2010 | 01:51 AM
tusabes's Avatar
Mercedes
I assume youll be replacing the relay too...can you take some pics of exactly where it is, for the rest of us?
So we know exactly where to go to pull it out in case of emergency/
thanks!
Old May 1, 2010 | 09:35 AM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
airmatic pump relay is relay "O" under the hood
Best to replace it with Hella relays
Old May 1, 2010 | 02:13 PM
Gondon's Avatar
02 S500 Sport
Fixed, Uncle came out with me and we got everything off.
Car is up right now, but I didn't screw all the bolts into the spikes not enough clearance because of pump size..its wider a bit and I cant screw the tings in without cutting into the pump. So I'm baby it to the shop and have them fix the rest because basically only 1 bolt is holding the pump right now.
Also it was a ***** to make the old hose reach the new design.. its really far away.
Old May 1, 2010 | 03:20 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
I'm glad at least you got the pump installed!
Kudos to you for fixing it so promptly!
I'm sure your baby will be fine and you'll be driving in no time!!
Old May 1, 2010 | 09:06 PM
Arnee's Avatar
New pump should be plug and play, unless you tried to re-use the vibration dampener while the new one is installed.
You were supposed to buy a new hose if you bought a new pump because the new pump has a different dimension requirement for the hose.
When I replaced my car's pump with the new pump and new hose, it was literally plug and play.
I don't know why yours wasn't plug and play.
Old May 1, 2010 | 11:21 PM
Gondon's Avatar
02 S500 Sport
I transferred the rubber crap(new pump didn't come with them) and when putting the springs back on that OVAL nut that goes in right before the final nut just didn't clear it. Also on 3rd support part of spike fell off from rust. WE its not big deal. Ill just let me shop figure out how to hold the pump. THE Hose can reach just gotta pull it.
Old May 2, 2010 | 01:43 PM
Gondon's Avatar
02 S500 Sport
All FIXED! Thanks to everyone who helped me here and in PMS!
Lesson to be gained from this for anyone who still has the SIEMENS/TYCO relay switch to the HELLA RELAY!
