Stuck in Park.
I had just bought this beauty, it had shift problem and I had just got a new shift box, same problem. I need help.
if you are talking about a 1995 E320, you are in the wrong forum.
stuck in park
This is actually a 2001 S430 that I am having problem with. I drive an E320
your crank position sensor has gone bad, that should fix the problem
who replaced the shifter?
I don't see the relationship between the CPS and being stuck in park. See the W220 S-Class Owners Start Here sticky at the top of this forum. Under Transmission, it has links that specifically address the stuck in park problem.
Originally Posted by PlatinumEdition
(Post 4067077)
Originally Posted by Skylaw
(Post 4067117)
Go to the top of the W220 forum initial page, and look at the second thread.
my fathers 02 s500 had the same problem couple years back and that was the first thing that came into mind since I cannot find the invoice on the actual part that was replaced to fix that problem
I did find it, and thank you a bunch. It was such a big help. I was able to fix that problem today. What a rim job by Mercedes Benz.
was it the crank position sensor causing your problem?
Originally Posted by tusabes
(Post 4069480)
Originally Posted by cyosondu@msn.co
(Post 4069038)
stuck in park - fixed
Originally Posted by Jud Chapin
(Post 4069561)
What was the problem?? :nix:
so the new shift box you bought was defective too and gave you the same problem??
did you buy it used? |
(Post 4071172)
did you buy it used? There is always the possibility that (10% ish ) the switch under the break edal is bad and not allowing the solenoid to activate the plastic part which would make sense if the box was replaced. Very easy to find out as you can usually feel the solenoid activating if you press the brake pedal while holding your hand on the shifter |
Originally Posted by my06clk
(Post 4071335)
90% of the time its the pastic peice that needs to be removed. I did mine a few years ago.
Do you mean that plastic part is available by itself? Where? How?
I bought a used one that needed programming, but by then I had already disassembled my old one as per the thread. I ended up swapping the modules. That did it.
(Post 4072386)
http://www.youtube.com/watch?v=MDUmdD3koqE |
