ball joint replacement Tutorial DIY
Old May 10, 2010 | 03:34 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
DIY W220 ball joint replacement
This was performed on my 2002 S430 at 80,000 miles I notice that my front suspension was making creaking sound at low speed. from all the reading on the internet it point to possible fail ball joints or struts. I talked to a mechanic and he say it is usually the ball joint and struts are very expensive since they are Air spring struts. Since my brother has the tool from the ball joint replacement on his W211 E500. We decide to tackle the W220 ball joint replacement.
Here is my brothers DIY tutorial.
W211 ball joint - http://diyw211balljointchange.blogspot.com/
W211 alignment.- http://mercedes-diy-alignment.blogspot.com/
It took us 2 hrs to complete the first side. Took only 1 hr to finish the other side since we figured out the procedure. It is probably a good time to replace the brake rotor and pads too. You are removing most of the same parts anyways.
Separating ball joint is pretty spectacular. It cracks apart pretty violently. You will see some videos !!!!
Parts:
New Ball Joint $30-$50 each.
New Lower control arm $115 each on ebay.
Special Tool required:
Mercedes Ball Joint remover $99 on ebay
Mercedes/BMW ball joint separator $25 on ebay.
Larger sized allen wrench set
Larger sized socket and open end set. 17mm, 18mm, 21mm, 22mm.
Impact wrench would help speed things up.
Misc smaller socket for the mud guard removal.
Jack stands
Jack
1. Jack up the front end and remove wheels. Support with Jack stands. I placed the jack stand at the sub frame that is between the main lower control arm.
2. remove the front inner mud guard. – you can remove it partially so you can get to the lower control arm bolts.
3. Remove Brakes - 2 bolt at the rear of the upright. tie up the caliper with ropes to avoid stress on brake lines.
4. Remove ABS sensor - large hex bolt at the rear of the upright. also pop out the 2 sensor wire from its holder .
5. Remove lower tie rod bolt and separate the tie rod with the ball joint separator.
6. Remove the control thrust arm bolt and separate the lower control thrust arm with the ball joint separator. See Video!
http://www.youtube.com/watch?v=l9YM2qZaN_4
7. Remove the upper control arm bolt and separate the ball joint with the ball joint separator.
8. Remove the lower ball joint bolt. you have to tilt the front up right outward to get a good clear path to the lower ball joint bolt. Place something under the upright assemble to cushion the assemble when it drops. I used a cardboard box that is filled with wrapping materials. Separate the ball joint with the separator. See Video!
http://www.youtube.com/watch?v=Egq59Ot2ZhU
9. With the upright out of the car. Place it on the cushion Box. Use the Ball joint remover/install and press out the ball joint. Use a second extension breaker bar to hold the tool in place.
10. Press in the new ball joint with the same tool but reconfigured to install.
11. reinstall the ball joint bolt and Torque to specification.
12. reinstall the upper control arm bolt and Torque to specification.
13. reinstall the lower control arm bolt and Torque ball joint bolt to specification.
14. reinstall the tie rod bolt and Torque to specification.
15. reinstall ABS sensor.
16. reinstall Brake Caliper
17. reinstall sensor wire to place holder.
18. reinstall the mud guard
19. reinstall wheel.
20. Torque down the lower control arm bushing bolt when the car is at its normal ride height. This is important because The bushing will always be twisted if you tighten the bushing when the suspension is at the unloaded state. We used a car ramp so we can get under the car when the suspension is loaded.
You are done! and saved a lot of $$$. You can keep the tools or sell it back on ebay.
The car will feel more solid on the road now and no noise.
To see the larger pictures. click on the pictures on my blog. http://mercedes-w220-ball-joint-diy.blogspot.com/
Old May 11, 2010 | 11:53 AM
Oxygen's Avatar
W220 S65 AMG
Fantastic post! Well done and thank you!
Old May 12, 2010 | 02:23 AM
shellshock's Avatar
2001 Mercedes S500
Can the joint in this:
be replaced? both sides of mine are getting bad. Everything else is fine though!
Old May 12, 2010 | 01:16 PM
fkong777's Avatar
The ball joint on the control arm doesnt press out. if your LCA ball joint is bad. you like will have the main lower ball joint going bad too. I'd just do them both at the same time.
Old May 16, 2010 | 12:10 AM
ALEV8's Avatar
W220 S500
Friggin awesome writeup man!! Any more DIYs?
Old Jun 14, 2010 | 09:46 PM
METERSF's Avatar
2000 s500, 96 camaro ss #1734, 99 camaro z28, 07 z06, 2000 limited tahoe
Your write ups are great, very informational. Good to hv someone like u to share info on DIY. i really appriciate it.
Old Jul 9, 2010 | 04:36 AM
brenner's Avatar
2002 S320-CDI
Question
Great DIY! Any chance of getting the tightening torques for then various bolts? Thanks
Old Jul 9, 2010 | 04:38 AM
brenner's Avatar
2002 S320-CDI
Excellent!!!! Any chance of getting the tightenig torques from you? Thanks
Old Jul 12, 2010 | 10:25 PM
griego89's Avatar
W220 S430
I agree your DIY write-ups are awesome fkong. Your DIY brake procedure helped me a lot.
Old Aug 20, 2010 | 11:27 PM
daisound's Avatar
S500/2000, E320/01/wagon
Since you took the upright completely out of the Tie-rod, you have to re-align the car, 4 wheel alignment cost $360 from dealer. Unless you need to replace the tie-rod, you can replace the ball joints, trust arm, lower control arm without taken out the upright, tie rod, brake caliper or any of the sensor, pads and save lots of time.
Old May 15, 2012 | 08:08 PM
Johnrb's Avatar
2002 S Class 430, 2002 SLK230
Great help, I changed mine on both sides and it worked just as you described. The allen wrench for the ABS is 8mm. make sure you have one before you start.
Thanks for the detailed write up.
Old May 7, 2013 | 07:12 PM
jbpatents's Avatar
2002 S430 w/ AMG
Fantastic post. I'm going to do this replace, but would like to also replace the front rearward control arm. Any idea how it is connected to the airmatic and how I need to go about disassembling/assembling it to the airmatic? Thanks.
Old Oct 10, 2013 | 11:49 AM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
hey I did both of my driver and passenger side lower control arms but now I need to do the upper control arms any tips or suggestions ?
Old Dec 3, 2018 | 06:47 AM
Terence Debraux's Avatar
00 S500
I thought this was right 😐
