How to Report Problems to be covered under warranty?
2004 S55 ///AMG, 2007 E350
My 2004 S55 is under MB warranty for another 15 months. I took my car to an Independent MB shop last week for a transmission fluid/filter change. They did the work and their inspection of the car reported the following:
1. Left engine mount is worn
2. Lower control arm bushing is cracked
3. Thrust arm bushing/ball joint is cracked
4. Oil leak at valve cover gasket
5. Excess play at left inner tie rod
Here is my dilemma, if I take my car to MB Dealer with this list, I know they could not cover it under warranty. I need to report actual problems which will result in parts replacements which will be covered under warranty.
What do you suggest I should report as problems, given the list above???? i.e excessive engine vibration (for engine mount), imprecise steering (for tie rod, control arm and ball joint), oil leak at valve cover should be the easy one.
Any suggestions are greatly appreciated. Thanks.
2005 S500 4-Matic, 1978 450SL
I suggest telling the authorized dealer exactly what you did. You took the car to an indy for non-warranty work, and he identified the following deficient items that are covered by warranty. You would like the dealer to carry out the warranty work.
Unless the indy worked on those items, they should still be covered; but check the warranty contract to be sure.
It would not hurt to report the symptoms as well, but I don't see why it would be necessary if the indy's inspection was accurate.
Also remember that many "wear" items are not covered by warranty.
I know how the MB system works. If I take the car in and say one engine mount is worn, my CPO warranty won't cover it since it is considered were and tear. I have to say something like excess vibration at high RPM or something like that which will lead them to look at the engine mount and replace it.
Not really tusabes. I am not sure what to complain about so they change the lower control arm bushing, thrust arm/ball joint or tie rod. The car feels fine but I want to have these changed while under warranty.
Maybe I should just wait a little longer till something breaks.
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
I might just take the car in and have them look and replace these parts. I am not dealing with Fletcher Jones MB, I use the MB Laguna Niguel, they are very good.
2000 S500, Evo VIII MR, R35
Well, I took the car in and handed them my list:
1. Left engine mount is worn (Replaced)
2. Lower control arm bushing is cracked (Replaced)
3. Thrust arm bushing/ball joint is cracked(Thrust arm and bushing replaced)
4. Oil leak at valve cover gasket(new gasket installed)
5. Excess play at left inner tie rod (Tie rod and bushing replaced)
The Service Advisor at MB Dealer gladly grabbed the list and they took care of all five items plus found a couple of problems with the trunk closer. All covered under warranty, I just couldn't help it and asked how much would this have cost without warranty, he estimated near $4K.
I normally do not purchase extended warranty for anything and this being an exception was a good decision and has paid off.
The car's steering is taut and much more precise now, quite noticeable.
