Does this sound like bad wires?
Recently, I have noticed a bit of an interrupted idle, it's not a smooth surge like before, but a bit rough; and after coming to a stop after highway driving, it's more pronounced.
I am not sure if there is a loss of power across the band, but I suspect it's a little bit different..the roughness is just at idle pretty much, not when in higher rpms.
I ruled out a mass airflow sensor, as I was told the symptoms differ and I'd get a check engine light which I don't have, so are the spark plug wires the culprit here most likely?
