Problem with suspension- '00 S500
2000 Mercedes S500
So I've been meaning to sell my car for a while, but my love for it wouldn't allow me to. The other night I drove over a piece of tire on the highway. When I pulled in to my home i noticed a weird sound coming from the engine. Over the next few days I thought I noticed my car sitting lower than usual (bear in mind I installed a RB tech lowering kit). Now my car is so low that it's not drivable as the tire keeps hitting the fender. Here are some pictures. Someone please tell me I have hope other than spending thousands on a car I already lost out so much on..
2000 Mercedes S500
Yea it isn't doing anything when I unlock the car or even start it. (As opposed to it raising like it normally should) Any idea what part I'll have to replace? Thanks
If thats what happened, your pump is dead. Arnott sells replacements. You also need to change the relay, as that is the most common cause of a pump sticking on.... but in your case, since you drove over something there is also chance you destroyed some other part of the system too, causing the air to leak and pump to constantly run.
If the noise was heard after the car was off, get the new pump and relay. That should get your car back up again.....But if you notice the pump constantly running, disconnect battery and have the whole system checked for other damage/air leakage or else you will burn out the new pump too
2005 S500 4-Matic, 1978 450SL
Considering your description, I would check lines from the airmatic pump before replacing any struts. You probably do need a new pump now, but your struts may be OK.
On the other hand, if the "piece of tire" you hit was of significant thickness (a whole tire thick), you may have blown the strut.
1 Post
S500 Silver, Range Rover HSE Black
dix hills
My money is on one or more airlines that were dislodged when you ran over the debris. Take off the front passenger side wheel and see there are any poly lines hanging down (not connected) to the valve block and pump for the air system. Easy fix if so. Also visually check your struts while front wheel is off to see if the strut bag is torn or more likely ripped open and the system will not hold any air. I highly recommend ordering the parts from Arnott or Rover Renovations and finding a local independent mechanic to replace them if that his the case. Won't be too costly and you'll be back on the road. Best of luck and keep us posted.
Chin up!
Chin up!
2000 Mercedes S500
Thanks to everyone for the advice. But I had my car towed to a local shop that specializes in German cars and I was told it needs a new compression tank, a new strut repair kit, and 2 new front struts. The grand total came to a whopping $5,700!! I'm honestly fuming right now because the car itself, even in good working condition, would probably only fetch about $10-11K. I'm apparently all out of luck and hope. I really don't know what else I can do here. I was wondering if it'd be possible to raise the car just enough so that it's driveable? (I had it lowered using RB tech's kit) Or I was also wondering if I'd be able to get an extended warranty plan where they'd cover something like this. Thank you to those in advance for offering me some great advice. I really appreciate it...
1 Post
W220 M113K
http://cgi.ebay.com/ebaymotors/Air-R...item19b3eba69b
Not only should you investigate the Arnott option, jump on that tank if it fits your car.
Last: You struck an object in the roadway that did not belong there, causing this damage. Will your auto insurance policy cover it?
2000 Mercedes S500
Cheers
