Problem with Front Passenger Strut
Old Jul 29, 2010 | 04:16 PM
Das Geld 2's Avatar
SL55, S500
Ok, The diagnosis is when I exited my car I heard a very loud squeal almost a shriek outside. I assumed it was someone fire alarm going off or some siren. It's very quiet and piercing I begin to inspect why its only around my car and I hear it coming from the passenger wheel well. After 2-3 min it went away and then I heard a hiss like leaking air for 5 min until that side of the car sank on its wheel.
Is my strut bad? or where is the noise coming from the air lines or the strut itself. I turned car back on and it rose. After that it sank in 4-5 minutes and when I went to pull the battery so pump doesn't stick , the pump started blasting on I ran to the front turned the car off and pulled the relay real quick.
What is the issue, do I need a new strut or is it possible something got dislodged? That squeal was a very high pitch and tone. Just like this http://www.youtube.com/watch?v=BX7Ar...eature=related.
Old Jul 31, 2010 | 07:32 PM
Das Geld 2's Avatar
SL55, S500
Oki, I took wheel off and I inspected the strut it seems its hanging on by a thin little piece and fully disconnected from the frame(control Arm). Is this where the air is leaking from? I circle it in red the part, on my car this piece is fully not attached.
Uploaded with ImageShack.us
Old Jul 31, 2010 | 10:39 PM
Das Geld 2's Avatar
SL55, S500
Ok, I just inspected car all 3 sides rise when I push raise, the passenger front side is just hissing air and doesn't go up. I'm guessing it needs New strut replacement.
Old Aug 15, 2010 | 06:31 AM
ajkennedy's Avatar
S500 Silver, Range Rover HSE Black
Das Geld
Correct. Suggest getting both fronts since they typically fail near the same time as each other.
Old Sep 4, 2010 | 04:41 PM
Das Geld 2's Avatar
SL55, S500
Replaced with the Arnott
Here are my old ones:
