CAT warranty extension
Old Aug 4, 2010 | 12:31 PM
konigstiger's Avatar
'71 Pinto
Arrow CAT warranty extension
Malfunction indicator or rattling noise heard originating from engine compartment or from under vehicle may indicate reduced catalytic converter efficiency – a basis for failing the state’s smog check program resulting in re-registration denial. MB has extended the emissions warranty from 8 years / 80,000 miles to 10 years / unlimited mileage for MY04 SL600, and MY01-04 CL600 & S600. If for some reason you have not yet received a notification letter, PM your email address and I will forward documentation.
Old Aug 4, 2010 | 01:00 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Might that also apply to MY 2003 E class? Just curious. Thanks
Old Aug 4, 2010 | 01:03 PM
'71 Pinto
No, only models mentioned are included.
Old Aug 4, 2010 | 01:46 PM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
since 2004 S55 is not mentioned, it makes me wonder if it has different cats than S600? I ASSumed they had similar exhaust systems since they are both very heavy breathers.
Old Aug 14, 2010 | 08:49 AM
ccms21's Avatar
S500
I've got an 03 S500 with a rattling cat. Any idea if this is covered by them?
Old Aug 14, 2010 | 04:26 PM
tusabes's Avatar
Mercedes
DEPENDS if it is externally damaged, such as from running over something and breaking the substrate inside causing the rattle, it will not be covered.
However if the damage is solely internal it is covered by the 8/80 Federal warranty and possibly the extended warranty if you are over 80k miles.
Old Aug 20, 2010 | 12:53 PM
cyrus113's Avatar
2003 s430 4matic
My cat went bad on drivers side with 61430 miles so glad they have warranty mercedes is going to fix it after a lot of tests at dealership. Kinda funny they replace the whole exhaust not just the cat.
