Airmatic Paranoia
Old Apr 14, 2003 | 11:05 PM
apricotscrub's Avatar
Airmatic Paranoia
Ive had the airmatic warning come on, visit workshop. It went away in 10 minutes, i've heard horror stories with the 2000 s430 airmatic, my airmatic works fine, it says it goes up and down when u press the button. Will my airmatic break down and i get stuck with 6000$ in repairs with an out of warranty car?? Also what is the Dampening Shock button do, It has one red dot, i think it may be like sport suspension, but i cant tell the difference!!
Old Apr 14, 2003 | 11:54 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Re: Airmatic Paranoia
You could just have a bad Airmatic pump pressure relief valve, which was a known problem in early S-classes.
Old Apr 15, 2003 | 12:09 PM
MercManiac's Avatar
2004 S 600
Just get a full check out of system. MB knows all the bugs with airmatic. The real horor stories come with the ABC suspension system which is standard on S55 and S600
Old Apr 15, 2003 | 01:17 PM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
Merc, are the later MY ABC systems problematic also?
Old Apr 15, 2003 | 04:25 PM
MercManiac's Avatar
2004 S 600
What has happened in the past with ABC is that the entire car drops down totally on the wheels. If your driving while it does this it causes all sorts of damage.........
Old Apr 15, 2003 | 05:16 PM
Mmmm's Avatar
s65AMG, sl500
The dampening shock button tightens up the dampers giving stiffer suspension and more body control.
Old Apr 16, 2003 | 02:02 AM
mbtech208's Avatar
From what I've seen, both systems have about the same amount of problems. Neither is horrible, but they do fail once in a while.
