2003 Tail Lights
Old Apr 17, 2003 | 08:37 PM
jasonrosen's Avatar
2003 Tail Lights
I just bought a 2002 s430
I want to know if i can out 2003 taillights on the car
If so how much are they and where can iget them
Old Apr 17, 2003 | 08:44 PM
awiner's Avatar
2003 CL55 AMG
Been discussed many times. Do a search and you will find all your answers.
Old Apr 18, 2003 | 05:11 PM
jasonrosen's Avatar
i still dont understand can somone clarify this for me
Old Apr 18, 2003 | 05:29 PM
wmak8's Avatar
Here is some info quoted from another member Ansonnn:
Originally posted by Ansonnn
Is it a direct replacement?
THE ONLY DIFFERENCE IS THAT ON THE NEW LIGHTS, THERE IS ONE EXTRA PLASTIC PEG AND ONE EXTRA BOLT (I DON'T KNOW WHY MB DID THIS). THERE ARE TWO WAYS TO GET AROUND THIS AND THAT IS EITHER TO REMOVE THE PEG (BY SNIPPING IT WITH SOME SHARP PLIERS) AND THE BOLT OR DRILL TWO EXTRA HOLES INTO THE MOUNTING LOCATION. I CHOSE TO DRILL THE EXTRA HOLES TO KEEP THE WATERTIGHT CHARACTERISTICS OF THE NEW LIGHTS. YOU CAN USE THE RUBBER SEALS INCLUDED TO MARK THE HOLES. TOOK ABOUT AN HOUR TO REMOVE THE OLD AND INSTALL THE NEW TAIL LIGHTS ON. FORTUNATELY, THE CONNECTOR IS THE SAME. OH AND MAKE SURE YOU HAVE SOME TOUCH UP PAINT TO COAT THE HOLES AFTER DRILLING TO PREVENT RUST (YOU'RE DRILLING INTO METAL).
Looks like more LED's than the old one or is it just more reflective?
ACTUALLY, SAME AMOUNT OF LEDS BUT WITH THE PLASTIC BEING MORE REFLECTIVE AND MORE CRYSTALLINE IN APPEARANCE. BASICALLY THE RED PLASTIC IS MUCH MUCH CLEARER.
