01 S500 40k Cuts out, no power at all
Today I fired it up and it took a few extra seconds to start and ran rough. I put it in gear, went to take off and it barely accelerates at all, the only way it will even move is if you push down on the pedal about a 16th of an inch any more and it cuts out so badly it will only decelerate. I am wondering maybe its the spark plugs? I don't really know what to do but I would rather not go to the local MB specialist because they try to rape you... Any advice is appreciated!
If you hadnt mentioned that fuel deposit issue, and how it ran good after the fuel filter, my first reaction would have been a bad pedal. The electronic pedals on these cars have a very common failure where you push and they dont respond. See:
https://mbworld.org/forums/s-class-w...n-problem.html
But if your fuel system was that bad, perhaps there was still gunk in there and the new filter got clogged up again
I would try another fuel filter and see if that fixes it again. If it does, the new filter will probably get clogged again until your gas tank or other components may need to be flushed out.
