2004 S430 Express open close
Yesterday I have ran in to the problem where express open and close would not work. I have two keys and about two weeks ago I have used that function where it was working just fine. I have spent about 20 minutes trying to get windows or sunroof to open or close holding the key pressed and nothing. My question is: Is this function key dependent or is there settings that override this function? My friend tells me to reset the system by disconnecting positive connection from battery and see if it works after. Also I noticed an issue with audio unit where it would usually turn up the volume depending on speed or if windows are open, now its not responding to those events. Any suggestions?
Thank you very much.
I am not aware of an override and it should not be key dependent. If your key starts the car, it should operate the summer open/close feature.
Best wishes
