mattsvi
Old Sep 29, 2010 | 05:30 PM
mattsvi's Avatar
mercedes 430S
mattsvi
I have a 430S- 2000, I want to install an Arnott front strut. Are their step-by-step instructions, hopefullly with pictures? Can you let me know how to access this? Do I need any specific tool?
Old Sep 29, 2010 | 08:05 PM
xexpo's Avatar
2000 S430 140k (07/11)
Most of what you need to know is in this video.
Good luck!
http://www.bilsteinus.com/airmaticsh...all/index.html
Old Sep 29, 2010 | 08:57 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
There is also a step-by-step (the official MB documents) in post #12 at http://www.benzworld.org/forums/w220...oxy-fix-2.html
Old Sep 29, 2010 | 11:13 PM
xexpo's Avatar
If you're replacing your struts with Arnott's you do not have to perform either of the top seal related fixes (fix-kit or epoxy replacement), Arnotts you purchase will have the updated top seal.
It is basically a plug-n-play. Only item you may be missing are the bottom set screws, 2 per strut.
Mention this forum and you will get 10% off!
Old Sep 30, 2010 | 08:28 AM
Skylaw's Avatar
Thanks for the catch, xexpo; I had meant to refer him to a different post that gave the procedure for changing out the struts entirely.
