3rd brake light not working. Help!
Old Oct 13, 2010 | 11:41 PM
pwrofjoe's Avatar
2004 White S430
Hi guys,
I'm having an issue with my 3rd brake light. I recently had disconnected it so that I could remove the stock subwoofer. When I reconnected the brake light, it does not work. I thought it was the actual light, so I bought a new one from the dealership, installed it, and still not working. Interestingly, when I apply the brake on my car, a soft clicking can be heard in the rear of the car behind the driver side headrest. Anyone know what that is? My guess is that it's related to the brake light being out. Also, I wanted to check the fuse to see if that is what the problem is, but I do not know where the fuse box is, nor do I know which fuse to check. Any help would really be appreciated!
Thanks guys, you have always been very helpful.
Old Oct 14, 2010 | 05:40 AM
Viet_Amg408's Avatar
Pinto
There's no fuse for center rear mount brake light circuit.. did you check make sure you didn't reverse side connector?
Old Oct 14, 2010 | 10:45 AM
pwrofjoe's Avatar
2004 White S430
I'm sorry, but what is the side connector?
Old Oct 16, 2010 | 09:00 PM
pwrofjoe's Avatar
2004 White S430
Thank you! That was it!!!!
Old Feb 19, 2013 | 02:13 PM
Elmer.in.TN's Avatar
2000 s430
thanks
Thanks to pwrofjoe for starting the thread and many thanks to Viet_Amg408 for the answer.
Elmer
Old Jul 19, 2023 | 09:47 PM
Ribman's Avatar
W220 S350
Hi there, I’m trying to remove the 3rd Brakelight from my W220 but am struggling to undo the electrical connect. Did you pull your plug straight off or is there a technique to removing the plug. Regards. Robert
